TwinTurbo.NET: Nissan 300ZX forum - Re: afr too low at low rpm
Subject Re: afr too low at low rpm
Posted by Noncon (STL) on May 07, 2011 at 5:49 PM
  This message has been viewed 316 times.
In Reply To afr too low at low rpm posted by hijack on May 07, 2011 at 09:59 AM
Message You need to make sure the base idle is correct. Unless you have something like Conzultz, you will have to disconnect the A.A.C. and check/set it.
Just as an FYI, the mixture ratio feedback system (to adjust mixture) doesn't work below 1500 rpm.
An air leak could be the culprit as well. This should be checked before adjusting base idle.
KJ
